Hey all,
Been spending a lot of time sourcing parts for the Muffler Noise Gate and have the DC jack and the I/O jacks left to find. I have been having a tough time figuring out what I need. Been looking at getting a 12VDC Jack for the pedal, I assume this is a standard voltage, seems to be common in a lot of other electronics too.
Here's the Build Document for the Noise Gate: https://docs.pedalpcb.com/project/PedalPCB-Muffler.pdf
While I think I know what Voltage would be acceptable for the pedal, I do not know what the DC Jack should be rated for in Amps. I also do not know what the most inner diameter and outer diameter size is. Perhaps that can provide me with a bigger selection to choose from.
Next concern of mine is the AC to DC converters. I have seen many of these: https://www.taydaelectronics.com/dc-power-plug-2-1mm-x-5-5mm-x-9-5mm.html with the picture giving no hints of there being a cord connecting them to a power supply for a wall outlet. I'd love an explanation on how they work and if this is what I should buy (Not this specific model). If you have any suggestions as to what I should look for instead, let me know!
Finally, The I/O Jacks for the 1/4 inch Guitar Cables. Any preferable jacks for a 125B case?
Thanks in advance!
Thanks in advance!
