Madbean Current Lover oscillation
Chrisq206
I’ve gone over the pedal a bunch and I’m not sure what’s causing the oscillation. To be fair this Pedal is probably a little over my head, but I keep coming back to it to see if I can get it going.
I did do the update with biasing resistor.
A friend of my got it running really quietly, but once it internal trimmer volume gets turned up, off it goes into oscillation.
Any idea where to start on tracking down the problem?
I’m not next to the pedal now, so I’m going on memory as to what I’ve tried so far. Please excuse the lack of detail.
Cheers
I got it working. For some reason the oscillation happens when the input is grounded to the chassis, meaning it stoped oscillating when pulled the jack (Switchcraft) out of the enclosure and disconnecting the ground.
Ran out of time to trouble shoot the cause, but pretty happy that it can work at volume without oscillation. Need to figure out the grounding thing and time it better now
Any input?
Any input?
Are you using the multi choice enclosed jacks below:
I ended up requiring the in and out as suggested for the effects loop version. Something was was not working with the other way of wiring, but couldn’t figure out what.
It works now which is a minor miracle. I’ve left this project and come back many time over the last couple of years or so and now it finally works.
There is still one problem though
When I switch to the matrix setting there is signal, but no effect.
Any idea why tat might be?
I will probably post another thread on this
Very pleased the flanger side is working and I never use the matrix setting on my EH Mistress, but it bugs me that it doesn’t work
Any input?
Are you saying that with two grounds (one on the input, one on the output) you had oscillations? That might be a ground loop, at least that's what I have read, I've never seen one in the wild :oops: Where is the circuit grounded now?
This project has two ways to wire the input/output/switch (luckily!). As my other post said, I switched to the other wiring option and the pedal started working. Never did figure out what was wrong with how I did my initial wiring.
