pcb rookie
Looked at the component difference between the Green Russian and the Civilian.
I knew there was not much difference between the both and they are from the same era but I was surprised to see that the only difference was R22 that connects to the Q4 emitter (2k vs 2k7). I will probably socket R22 and experience with both.
just curious to see what are your thoughts and experience on how that single resistor impacts the tone sonic wise ...
I own a SUF Civilian and SUF '73 Muff. Curious to see how they will compare.
Listing to stories about the muffs in those days, there was difference in components due to tolerance and/or, components availability in what was to be an identical model/version ...
