Hi all, I've put together most of the Neurocyton with a charge pump board and running into an issue where I can't seem to bias Q2. No matter where I set the trimmer, it always shows ~17.4v (at 18v, with 17.5v at VCC). The trimmer seems fine, if I check the resistance, I see a linear sweep from just over 0ohm to just under 100kohm. I also tried removing the J201 and soldering on a new one, but no success. Any tips on how I can troubleshoot this? I have no background in electrical engineering, so please assume I know very little!
Some extra details:
Some extra details:
- When I play through it, it mostly makes no sound and becomes a (very quiet) sputter-y fuzz-like distortion when the gain knob is turned all the way up.
- I'm using PedalPCB's charge pump board with a TC7660S instead of a TC044SCPA (I believe they're compatible?)
- If I try to bias at 9v, the same thing happens on Q2 but at ~8v. Q1 and Q3's biases become too low, while Q4 seems to be fine.
- When I first soldered the board (before adding pots), I was seemingly able to bias all the pots at 9v
