Chuck D. Bones
Circuit Wizard
Sometimes I'm troubleshooting cars. It might be ok when a pedal makes a farty sound, but it's never ok when a car does it. When my '98 Jaguar XJR suddenly started stalling at idle and making farty sounds from under the hood, I knew something bad was going on. No Check Engine light, although a scan showed several pending faults including running lean. That and a listen thru a short piece of hose pinpointed the problem:
The gasket on the outlet side of the blower had failed and was sucking air into the intake tract, bypassing the throttle and air flow sensor. Here are the failed and replacement gaskets.
Jaguar mounts the supercharger upside-down, with the inlet on the bottom and the outlet on the top. The gasket goes between the aluminum duct with "V8" on it and the blower. Yeah, there is a supercharger hidden below all that plumbing. Lucky for me, the outlet side of the duct has flexible couplings on it. I was able to remove 4 bolts, then lift the duct just enough to slide the old gasket out and the new gasket in. I spent more time looking up the torque spec for the bolts than it took to R&R the gasket.
That 4.0L V8 engine has just over 200K mi on it. I've replaced belts, hoses, timing chains and head gaskets and that's about it.
