So years ago, when Electra made a line of guitars and basses, discontinued some time in the 80's, that featured built in effects that could be swapped out via plug-in modules:
A couple of drawbacks to this approach: only two effects could be used at any given time, each module only had one control on the front, so adjusting other parameters required opening up the back to twiddle the corresponding knob.
I regularly enter the annual Winter Build-Off over at TalkBass; the theme this year was rather broadly defined as "Rebirth/Renewal", so I decided to take a fresh approach to the onboard effects by using a Daisy as an onboard effects processor. I've decided to address some of the shortcomings of the by using by including a display in the upper horn of the bass and replacing the two pots with rotary encoders that can be used to adjust any of the parameters . My build thread over there focuses primarily on the bass building aspects; I decided to post a thread here to deal with the Daisy development side of things.
