Help finding/subbing a few components (BA282, LM13600, C150K pot)
For about 7 months I've had unfinished PCBs for a King's Hand Overdrive (King Tone Duellist Side B https://www.pedalpcb.com/product/kingshand/), and a Waddle Box (DOD FX25 Envelope Filter https://www.pedalpcb.com/product/waddlebox/).
I wasn't able to find the following parts at the time and have only periodically checked back, mostly waiting for Small Bear to reopen, and I think I missed the window on their BA282's:
(5) BA282 - King's Hand Overdrive
(1) C150K pot - King's Hand Overdrive
(1) LM13600 - Waddle Box
The C150K pot is more of a confusion for me as I'm not sure what other names/specs that type of pot goes by (I've only used A and B pots before).
Does anyone happen to know of a legitimate source for BA282's right now, or if there is a substitute? There are some price gouged listings on eBay for them but I've read a lot about fake components on there. I might just be out of luck for now with the global shortage of everything, but just throwing this out there hoping to get lucky.
And does a C150K pot go by any other names, and lastly are there are subs for the LM13600?
Thanks!
You could use a BAS33-TAP if you can't find BA282.
C taper is Anti-Logarithmic (Reverse log). Those are tricky to find in small quantities at 150K. You can approximate with a taper resistor or use the nearest available value (which is what I did with mine)
LM13700 is a suitable replacement for LM13600, Tayda has them. The through-hole version is End-of-Life so get em while you can.
I bought some BA282's from Pedal Hacker some time ago for a batch of Paragon's: https://www.pedalhackerelectronics....pping-Diode-Vishay-MA856-sub-p/ba282-vish.htm
You can use BAS33's in place of the BA282's. I think they might be easier to find...and cheaper.
Stomp Box Parts has the C150K pots: https://stompboxparts.com/pots/16mm-potentiometer-short-pcb-leg/
Tayda has the LM13700, which is what I used for my FX-25 clone (Madbeans Flunkee): https://www.taydaelectronics.com/lm13700-lm13700n-operational-amplifier-ic.html
Dammit...you beat me to it! :P
Thank you for the breakdown! I'll likely do the taper resistor trick. Good to know that there's an easy comparable component to the LM13600!
Thank you for the heads up! I thought I'd checked Pedal Hacker and saw them as out of stock but good to know they aren't. And definitely good to know that BAS33's and LM13700 are comparable.
Oh man, if you're looking to sell this I will absolutely PayPal or Venmo you!
