A - is the trem side the same circuit as the moonshot?
stompboxparts.com
It is.I'm assuming this is Reverb -> Tremolo? Even though this is a 2 in 1 PCB, I can still wire an order switch between the 3PDT boards right?
Thanks for replying! I love that you are putting out these very practical pedals.It is.
Electrically yes, you could wire up an order switch... You'd just need to ignore the red pads in this pic and wire them up exactly like you would two separate PCBs.
Physically, however, I'm not quite sure where the switch would fit.
It’s a 1590BB build, right? Just use long-leg pots and a 1590C enclosure!It is.
Oh yeah, I forgot to mention that for the two middle-adjacent pots, either long 9mm pots would have to be used, or regular offboard-wired solder lug pots (in which case the faceplate couldn’t be used— at least not without some light modification and clever knobbage)You would have to use this type of 9mm Pot:
Hello how are you?It is.
Could you help me or indicate how I can do this inversion?
