dawson
Now, I've always been a firm believer that a pedalboard should be a DIY thing, following the logic of, "who knows what you need from your 'board better than you?" However, I'm learning that not everybody out there's got DIY in them.. it's sad but true, and if one of these people is a bandmate of yours, it's your responsibility to help that person.
Anyhow, this guy's one of my best buddies, so I want to set him up with something that'll work for a long time. I'm using the same basic design as a 'board I built for myself awhile back:
This time though, I'm not going to build it as tight as possible, but I'm going to focus on this thing being usable for all sorts of setups, AND, it's going to fit in this badass suitcase:
I figured if it's going to be universal, it's going to need a couple inter-changeable parts:
Here it is partially assembled to accommodate a volume pedal:
The plywood is finished with 1/10 India ink/water, then brushed with boiled linseed oil along with the pine pieces.. Like a dummy, I left the plywood out to dry for a long time on a surface that wasn't flat, and the large bottom piece totally warped a bit. Figuring out how to get that flat- I may have to rebuild it with thicker stock:
I'll be posting more pictures as this progresses.
Thanks for looking!
Thanks for looking!
