Paragon *no sound from CH1
Lewage
Just finished populating this board this afternoon. Hooked it up and CH2 sounds great. Switched to CH1 and I get almost no sound. *If I mess with the pots enough I can get the occasional quick fart out of it.
Anyone notice something stupid here?
Can you take some additional pictures? These are very difficult to see resistor bands and solder joints. :)
R4 looks like 39kΩ instead of 33kΩ but that's a non-issue. Are you getting signal to the pcb (@ CH1 switch)?
Yes. I ran an audio probe across it and it works at every joint. That said, it was my first time using one, so I may not have been doing something correctly.
I knew about the 39ohm resistor. I was out of 33s and figured that shouldn’t really have an effect.
I even swapped the ICs since I knew channel 2 was working.
So I lied about pin 1 I'm getting a signal, but it fizzles out if I leave the probe on there. Also noticed that I get no sound from pin 2 unless I "accidentally" bridge 1 & 2. Then both pins do the fizzling out thing when I probe them seperatly.
I set the dip switch and pots of both channels the same so that I could switch back and forth to compare. That's when I realized how bad pin 1 on IC2 was sounding.
I'm thinking it should be around -4.50v, but...what about pin 3 of IC1?
Right around 7.50
I have another board. I think I'm going to try and salvage a couple diodes and move on.
I'll keep this one around in case I get really bored.
I REALLY appreciate you troubleshooting this with me!
