if you're aiming small, Blackheart Little Giant is 5 watts of mostly clean. if you're shooting for more watts, whatever that cheap Chinese rebadged Laney combo amp is
I have a Little Giant and it is quite clean. I do find it a bit dull sounding though.
I’m looking at the 15 watt mono price and I think I’m liking it
I have that one - traded 2 of my homebuilt pedals for it. I retubed it and its friggin excellent, great breakup, clean for as loud as I need. Plus an effects loop and 1w switch (although Im not sure its actually that low). Blues jr went into the amp closet and this one is occupying its spot. I've heard conflicting thoughts on what its based on. any idea?
you get a single preamp stage and a tmb tone stack ... the proper approach would be to add at least a cathode follower ahead of the tone stack and a gain recovery stage after ... but this is the way of two tube lunchbox amps
One thing to keep in mind is the idea of a low wattage tube amp AND being a clean pedal platform is really hard to find. Most small tube amps have very little headroom and it's worse if you use humbuckers or hotter pickups. I would suggest something like the new fender vibro champs. I had a silverface champ and it was awesome and would stay clean most of the way up the volume. It's a loud clean 5 watts. As an added bonus they have digital reverb and while not as lush as tube spring verb is better than nothing as the originals had no reverb. I've seen them going used around 699.
This....
If what you want is a clean pedal platform to let your pedals shine then unless you're really playing low volume, you're going to need some headroom. Meaning, probably at least 12-15 watts or in the "Fender Blackface Princeton" range. (That would be an excellent choice btw).
25 watts is probably better. This part of the reason I've moved mostly to the digital modeling domain. My wife has a condition where she can be hypersensitive to loud noises and even from across the other side of the house me cranking out riffs to "Custard Pie" on my tube amp just isn't going to fly anymore.
The UAD Apollo system is simply astounding at how close it can sound and feel like a real amp. In my "MOST HUMBLE OPINION" heads and shoulders above anything else out there in the digital modeling world for studio applications (E.g., Nueral, Helix, Kemper). But even then, only certain amp models, there's some real dogs in their line up too. (I hate the Plexi model, and the 55 Tweed model) But 99% of the time I use the Fuchs Overdrive Supreme model, clean channel, which is just a great clean pedal platform.
Having said all that, here's a real unintuitive suggestion I'm going to make. There was recently a thread about Dumble amps (and a lot of dumping on them). The one thing I really like about "Dumble-style" amps is not the super saturated gain channel but rather the big bold fat clean sounds you can get. Makes sense since the original amp D made was a modified Bassman head for Robben Ford.
Most of the Dumble clones out there are stupid expensive but there is one really really cool amp that I've been eyeing. The VHT-D-Fifty.
It's a point to point hand wired clone of a Dumble-esque circuit. But I'm mainly interested in it as a clean pedal platform. Basically a dual 6L6 50 watt amp. I'd probably never use the gain side, but just the clean channel. The heads can be had for around $900, which is pretty ridiculous for PTP hand wired amp. (Note that it doesn't solve MY particular volume issue hahaha.)
Another unintuitive suggestion I'm going to make, is the Mesa Boogie Mark 5:25. I sold mine because I only ever used the clean channel. Oh but WHAT a clean channel. Like most Boogie amps, it's "option overkill", too many damn knobs, and toggles, pull this push that, which I really tired of. But the clean channel is the same circuit as the Boogie Lonestar, which is one of the best clean tones ever, especially the 6L6 version. awesome pedal platform. I really regret selling it, but they can be had used for a reasonable price.
This is the amp I currently use, Revv D20. It was designed to be an extremely neutral sounding clean pedal platform with a built in Torpedo Cab IR/Reactive Load/Digital interface. It's actually quite a killer sounding little 20 watt amp out of the box and can be further dialed in with some better tubes. My problem with it (aside from just being a fickle gear slut) is that it's a little TOO neutral sounding. I can dial in some Blackface Deluxe type sounds or some Bassman clean sounds but it never really quite gets there.
I think maybe if we work backwards on your question, starting with what your budget is, it would help narrow down what you're looking for. There are LOTS of choices out there these days at every price range.
Edit: Dang, late to the party as always....Congrats on the Blues Junior snag! There's a huge rabbit hole you can fall into with that amp, lots of useful mods available for it, dedicated forums, etc.
This....
I used to have a Fender Prosonic when they first came out. I liked it. But in the end it was the "clean" channel I used almost exclusively - it sounded fantastic. Cranked it was better than most amp's dirty channels.
Then I had (actually still have) a Badcat Hot Cat 2x12 combo. Stupidly heavy and the dirty channel got old after a while, but again the clean channel - with just a volume knob and the global Cut knob - is glorious. Cranked or clean it's a beautiful, punchy sound which takes pedals well.
This....
I ended up getting a fender blues junior I love it!
Even after you’ve bought, played, fell in love with, modded, and eventually sold after years of recording platinum tracks through it….we’d still be recommending amps to you. It’s easier to just to roll with it. ;) :ROFLMAO:
I’ve come to learn that you can’t fight this place, once you’ve entered this forum…there is no turning back…..😈
btw, the Magnatone Twilighter is a groove tuber. Also, I briefly had a Mesa Boogie 15/25/35 that I would have still been using had the dealer not tried to fix the brand new amp twice and fail. It‘s a very tight amp.
Magnatone twilighter? I’m afraid to google this cause I’m afraid I’m going to love it….🤣
Update: I looked it up….why…..why did I do this to myself?
