This Univibe schematic - What part would you change to brighten up the tone
nznat
This pedal plan and build works great mostly, but the vibe tone is more on the deep and darker side mostly, i cannot seem to get to the brighter aspects of the vibe throb? any suggestions or components on this schematic anyone sees that could be changed or adjusted? Or is it mostly based on the bulb and LDRs ?. Also, The mini tuning pot is at its limit, cant turn anymore, so don't know what would happen if i had more adjustment in that direction, yet the best tone is back a tiny bit, so that tells that tail. I went into a local store with this vibe build. I plugged it in side by side with a dunlop jimi hendrix univibe, and the dunlop had that brighter squishy / chewy tone, nice, yet my build with the proper bulb etc was way more organic sounding, yet the brighter chewiness was missing from my pedal. I couldn't get the brightness. if i can get there, the pedal will be epic. help!
Some housekeeping:
1.) It’s generally considered bad form to post the same request/questions in multiple threads. It causes confusion, with people responding back in both.
2.) In your previous post about the bulb issue, you said you’ve assembled three of these SMD Univibe boards and they sounded fine. Did you do something different on this one?
3.) I’ve seen you post 2 different schematics now. Which schematic represents the pedal in question?
Increase R3 (47K) to something much larger, like 4.7M.
Does that increase brightness overall? for the preamp, , or only for the top part of the sweep of the throb? as it seems its position is not within the management of the bulb sweep, more so just at the input. ill try it though. much appreciated for any info
that increases brightness overall, for the preamp, , or only for the top sweep of the throb?
Some housekeeping:
first schematic was the original design, second was my modified version, which only has added relay switching to it. same stock tone components though
It increases the overall output volume and should affect the top end. It's a well known univibe mod.
i found 2meg was really nice. you lose a bit of bass. i think a mini switch with something like 3 different resisters would be nice option eh. thanks for the info.
Just turn the volume down. You dont need a switch. What you are hearing is boost past unity gain on the volume control.
nah current the volume / gain control gives a different effect. the change of the resister actually gave high mids, NOT brightness actually. clearly mids have increased from the resister change. And using my volume control thats already there, it only changes the volume, no brightness changes.
It’s no different than changing the output resistor in a Fuzz Face.
More output = More Mids.
Good luck.
