Chuck D. Bones
Circuit Wizard
6418 tubes were originally designed to be used in portable, low-power (2mW) amplifiers.  Tube part numbers that consist of four digits are hi-rel, ruggedized tubes for military applications.  The datasheet is dated July 1, 1963.  The date code on the box is Dec 1978.
I think it sounds great. Smooth transition from clean to mild distortion to fairly crunchy as one turns the GAIN up.
A have a few other ideas for using these in pedal circuits.
Turns out that bypassing the filaments to ground is unnecessary because the AC resistance between filament and ground is only a hundred ohms or so.
