Paragon Breakout Board
billywonka94
Is the dual foot switch breakout board reversible? I think I soldered the switches on the wrong side of the board. Every pic I've seen of other people's completed builds have had the switches soldered on the reverse side. I've been having trouble removing all the solder and removing the switches. Is that necessary? Seems to me that it should work either way, just wanted to be sure. Sorry if this is a dumb question; I'm still fairly new to all this! Thank you in advance.
Not exactly, but I believe it will work.
You'll want to cut this trace on both footswitches.
You could add the jumper shown in green (on both footswitches) but it really shouldn't be necessary in a low gain circuit like this.
