DAJE
IMPORTANT - READ FIRST:
I have very carefully triple-checked ALL of the resistors and ALL of the capacitors, and they are definitely all correct. I test all of them before soldering so I know that they're all within spec.
The 3102 and the 3207 have been tested in my other chorus pedal where they function correctly and with plenty of top end.
I also know that the pots are the correct values and in the right places. I might not have tested them before installation so I can't be certain they're within spec.
I have tested all 5 transistors and swapped the positions around. They're all 2N5088s and they're all in spec, as far as I can tell, with a gain between 350 and 450.
I did the mod where you replace D1 and D2 with 2.2uF MLCCs. Neither affects high-end content.
I have adjusted the trimmer very carefully and while it seems to have a slight effect on the high end, there's no point where the highs aren't cut.
The high cut is the same whether or not the PCB is boxed.
It isn't a subtle effect; the pedal is unusably muffled and it sounds like I've zeroed the tone on my guitar and my amp, while my other choruses - one bought, one home made - have plenty of high end.
