coachseeley
I genuinely gave effort in searching previous posts, but could not find any without being further confused.
I have a customer asking for "soft bypass" switches in his requested pedal.
I am not sure which relay board I need or which switch either. Other searching tells me to use "momentary normally open" switches.
Would someone be so kind as to post a direct ink to the footswitch I need and the PedalPCB relay board I need to add the soft touch bypass switches for the pedals. I am placing a Tayda order soon, so Tayda supplied would be great or StompBoxParts would work also. None of the current builds are buffered bypass.
Thank you.
Thank you.
