Mike McLane
I was researching about signal caps only to discover that there IS a polarity to non-electrolytic caps.  Apparently there is. . . . inner foil-dielectric layer-outer foil. . . the outer foil functioning as a shield similar to audio cables.  The lead coming off of the outer foil should be oriented "toward ground".  Would it be helpful if the capacitor slots in the PCB's were marked similar to diodes and electrolytic caps so we know how to orient them for the least noise?
