Chuck D. Bones
Circuit Wizard
James (HamishR) sent me a schematic of a Vemuran TSV-808 he had modified. I did my thing with it and came up with this. It's pretty close to a Timmy III. The only short-coming of the Timmy (IMHO) was the weak midrange when TREBLE was dialed-down. I reconfigured the last stage to resemble the mid boost stage in the Friedman Brown Betty. It doesn't take much boost to bring the mids back to life. The MID control could be an internal trimpot or hard-wired for a 3dB boost. D5 adds a smidge of asymmetry to thicken up the sound bit. R8 & R9 are there to smooth out the taper of the DRIVE & TREBLE pots, respectively. Like the Timmy, it's a "transparent" low-mid gain OD. If you want more sustain, you can use it to push another dirt pedal. Or get crazy with C3 & R4. All component values are negotiable. You can try different opamps if you're like that. I recommend tantalum for C11, film or silver mica for every other cap except C10. Any Ge diode will work for D5; leakage is not a concern.
