DRBEN
- Build Rating
- 5.00 star(s)
At the beginning of my post I would like to welcome you all, this is my first post
Now to the point.
I would like to boast about the result of my work. This is an exact copy of the BOSS CE-1 chorus from BOSS
I named it LEGEND
The differences between the original include
-possibility to supply with a standard 9V power supply, or BOSS polarization if you prefer
- hardly available analog MN3002 delay line replaced with a newer chip with identical parameters
-reelational preamplifier which, when properly set, beautifully colors the sound
- perfect sounding chorus
-very original vibrato.
-option to use the effect in stereo configuration
- powder coated housing, the paint has a unique structure
- UV print applied directly to the housing
- definitely smaller size, less emergency than the hard-to-reach and very expensive original
- housing dimensions are 187x118mmx38mm
Samples for one of the first chorus versions:
I started working on the effect in 2019, of course I first made a few prototype circuits with a positive or less positive effect.
However, what it presents is currently the final version.
If you have any questions, feel free to discuss.
Regards!
Now to the point.
I named it LEGEND
Regards!
