Synchrony Pedalworks
I could use some guru help with troubleshooting this issue. I have a great run of pedals working on the first try, but my luck has run out.....
Just last week, I made a Heliodor and it worked. Yesterday, not so much. When first tested, the output had low output and gain. The Drive knob did not do much. The testing was ended quickly, because Q3 got really hot. I have tried to get voltages, but the smell of "magic smoke" is lurking. Attached is the schematic and pictures.
Right now, I have exchanged Q5. When Q5 is removed, the heat is gone, but it returns with a new 2N3906. I have not gotten voltages, because Q3 gets hot quickly and I am fearful of frying it (if not already done). I have reflowed all the parts surrounding Q3 without luck. The parts, for the most part, are verified as correct in specs. The only deviation is that I placed a parallel caps for C13, which is now 12.2 uF.
I could use a good plan for attacking this trouble shooting. With my pictures, I question a cold solder joint with the ground for the two PCBs. I was going to address that first. If the problem persists, does it sound like the issue is with the powering of VA to the Fets? Would you all evaluate that line of parts first or do I need to look elsewhere? Would you remove Q3 and get voltages for the other Fets?
Thanks,
AE
Thanks,
AE
