nznat
Hello.
I have this uni-vibe i built from, the diagram attached. Its pretty good. What i want to do is put a wet / dry dial on the pedal.
The reason is, the pedal schematic has a really nice pre-amp in it, and also the vibe is pretty good, yet a lot of pre-amp tone comes through, and i want to be able to dial more vibe effect into the mix and remove some of the pre-amp effect. I'm sure ill get a much better vibe effect that way.
Any ideas anyone, or who can i talk to about this adjustment / where on the circuit could this wet / dry be added. i.e. both pre-amp and unvibe effect are seperate parts in the circuit, so i want to be able to shift percentages of each = like having 30 percent pre-amp and 70% univibe effect. Yes i know, the preamp is essential for the tone, but even a 10% shift would create a big vibe effect taking place without the pre-amp getting lost, because the pre-amp goes above unity, so should be fine.
thanks
thanks
