Hi,
sorry to hijack this thread but Dr. Trebor/Pharmacist threads are quite hard to find ...
This is actually my second build, my first was Son of Ben and it worked right away. So I got cheeky and tried Dr. Trebor (I got the PCB and all parts from musikding in Germany, so good quality with all parts).
However I'm having trouble with the "mach schau" circuit. The normal channel is working alright except the volume pot but I suspect that this has something to do with "mach schau" not working.
I suspect the problem lies within the wiring of the mach schau switch. For the bypass-switch I used the EZ 3PDT board but for the second switch there was no board and no documentation. So I wired it as followed:
Row one of the switch to lugs 1-3, the middle row to lugs 4-6 and the third row to lugs 7-9, always left to right on the switch.
If I engage "mach schau" the pedal goes mute and the second led won't light up. I'm not really good at trouble shooting (yet) but you've got to learn somehow. I measured voltages and what got me curious is that R36 measured 9 V at it's input and about 1.8 V at its output when engaged.
R35 always measures about 7.4 V at its input and output although the value of it measures correct (4.7k).
Should I post some images (if so what would you need) or would certain measurements help?
The normal channel sounds alright by the way, no spluttering and a very "voxy" tone, just as I expected
Any help or hint is much appreciated.
Thanks
Jan
Thanks
Jan
