Don't just check the bag, check the component.I will check that. I’m pretty sure the bag says 100p… I mistakenly ordered 400V…
That shouldn’t affect the EQ. the letters only tell you what the taper is.I used the NE5532p… I just noticed that this build uses a B100k for the volume. I’m going to try an A100k like the original…
This is confusing, Did you change the Volume pot to A500K (Should be100K) or Gain Pot to A500K ( Should be Linear)So I changed the pot to an A500k and that was it!! They’re not exactly the same, but they’re not MILES apart.
