Out of curiosity, how do you power 2 heaters from 9V input? I can imagine 12V as series 6+6 but is it enough from 9V?
Is it verified and available? It reminds me of some preamp *wink* that would be nice for my band's bass player.
The very first tube pedal I ever built was a Matsumin valvecaster, which uses 9V for the heater running in series, and that put the thought into my head that 9V is okay. In testing I've run heaters as low as 8V, but below that they start to drop out because the tube isn't hot enough to pass signal anymore. 12.6V is what the datasheet tells you, but 9V works, pulls less current, and extends the tube life because it isn't stressing the filament as much.
The design is verified, but not yet available. I do have 4 boards on hand though, maybe I'll make those available for the first 4 people until the Chinese national holiday is over and I can get more PCBs made. Enclosures will be a little tricky though because of the slot on the side for the switch, I can't drill that accurately at home because my CNC isn't big enough, so you're pretty much stuck with Tayda. I do have a verified Tayda drill template though.
So I guess stand by for info on availability.
			This is a grotesque query... and speaking of related costs to building these tube circuits, what are people doing when running multiple pedalboard power supplies? This is going to force me to buy a lil cioks, I can feel it in my bones. Do you run two power cords or is there something better than a baby surge protector underneath?
I run a gigrig supply, which has served my pedal gluttony well but let's say I suddenly want to add 3 tube pedals. That's over 300 dollars in gigrig "mr universe" adapters. Seems a better investment to get a 4 outlet cioks at a much lower cost and have a spare high draw line for the next Nathan/Jeff collab that I won't be able to live without. (Cough cough, ehx tube comp, cough)
I like the Cioks because of the chain output from the DC7 so I can run another Cioks supply straight off that. Cioks are expensive, but my personal pedalboard has 12 tubes on it, and Cioks is the only thing I've found that can handle it.
			where did you get the faceplate made?
Faceplate is a 0.8mm PCB that I got from JLC.
			Oh my god
Will you be offering the faceplates for purchase as well?
Faceplates will absolutely be available as well, I'm planning to stock as many of those as I have PCBs. They came out really sharp, and I love the look.
