Hello again! Back with another isosceles boost build. For whatever reason I have the most trouble with this circuit. This time around, I’m having some volume control issues, where if I turn it all the way down, some noise is still coming through like the ground or something isn’t strong enough and when i turn it up, it doesn’t have much gain. I’ve tried everything from changing the pot, checking the values of the pot, touching up connections on both sides of the PCB, cleaning, even changing jacks and nothing. I had something similar happen to me on another board and I just jumped the connections for the volume and set it to full at all times. It didn’t work well with my interface though so I’m trying to add it back. Should I try a a10k?
Thank you!
Thank you!
