eh là bas ma
Hello,
Here is a sound sample i made, max gain at 0:55 :
This is one of my first stompboxes ever. A cheap clone bought second hand on internet, years ago.
The circuit has been sold under various brand names : Xpression SD-100, Boston SD-100, Odak SD-100, WSL SD-100, Harley Benton SD-100...
I always liked its sound, but never could find the real original circuit. That's too bad because the clone is probably made of cheap parts and some settings are unusable because of some loud background white noises introduced in the signal. Happens when High or Sustain are set anywhere in 2nd half of rotation, also when Dist is set on high values. There's a big "shhhhh" between each note, it's so annoying... It gets better with a noise gate, but not totally fixed, unfortunately.
I thought i'd try my luck on this forum, just in case...
I already tried to find out what it is 2 years ago, but no luck. Here is the previous thread i started about it, you'll find some pcb pictures reply #9 :
Can someone recognize this specific distorsion ? Or at least something very very similar ?
No ? Please close your eyes, empty your mind, listen to the sample from 0:55' once again... i am begging you !
3 ICs, 14 transistors , 9 diodes, around 60 resistors and 30 capacitors. What could it be ?
I can provide better pictures if needed.
Every observations, comments, wild guesses and straight answers are welcome.
Thank you for your help.
How to reduce background noises on a smd-built distorsion clone ?
www.diystompboxes.com
