cthilley1
I'm building a Mach One overdrive and had a thought. I would like to toggle between two volume pots at the end of the circuit to achieve two different output volume "settings." This is what the output section looks like, pretty simple:
Could swapping between two pots be achieved with an SPDT switch if it were wired in this way? Or will this cause problems?
Would at least a DPDT switch be the only good way to do this, to break the flow both before and after the pot while keeping it connected to ground? I didn't know if that might be redundant for some reason:
Extra info: I am already adding a 3PDT switch, one pole/throw is dedicated to adding hard clipping diodes by connecting to VREF, and i was hoping I could use the second pole/throw to achieve toggling between two output volume pots to compensate for volume loss of adding the hard clipping diodes. I'd like to (ideally) use the third pole/throw set for an LED indicator, but can forego that if I need to.
Some education here is appreciated!
Extra info: I am already adding a 3PDT switch, one pole/throw is dedicated to adding hard clipping diodes by connecting to VREF, and i was hoping I could use the second pole/throw to achieve toggling between two output volume pots to compensate for volume loss of adding the hard clipping diodes. I'd like to (ideally) use the third pole/throw set for an LED indicator, but can forego that if I need to.Some education here is appreciated!
