Robert
Reverse Engineer
TUBEKLØN is the world's first tube-based mythical beast overdrive pedal interpretation. After deconstructing the classic design, the minimum gain flat bandwidth feature was removed, instead offering up that sweet midrange boost as the new minimum gain tone. Based on my NEOKLØN architecture, the diode/opamp clipping stage was replaced by a triode, as was the summing stage, which now drives a passive tilt style tone control. The entire circuit is recreated using five transistors, two triodes, and zero opamps. Tonality is same as the original, except at high gain, where you get real tube breakup and sag, instead of opamp clipping.
This kit contains a fully assembled and tested circuit board, tube, and enclosure; you only need to perform final assembly, placing items into enclosure and buttoning up. Keep in mind tube takes about 30 seconds to warm up after power is applied.
PedalPCB is in no way affiliated nor endorsing this product, I just thought it was cool.
With that said, for $249 I feel like it should come fully assembled and ready to rock. Not sure I'm a fan of this new "just tighten the hardware" DIY kit trend... but yeah, I kinda want to try one.
