jwyles90
- Build Rating
- 5.00 star(s)
Just finished putting this one together, all in all it was an easy and fun build. I've only heard good things about this circuit in general, but given how expensive they are these days I've never had the chance to play one, so I was stoked when we finally got a PCB for it. Would I pay $500 for one? Definitely not, but overall I'd say it's unique enough to warrant the hype that it gets. The drive itself sounds really nice and has a wide, useable range from gritty boost to full on, saturated fuzz type stuff.
The sag feature is interesting. It took me a second to know for sure if it was actually working or not. Seems to me, on my build at least, that the trimpot basically needs to be all the way open to get the most noticeable effect out of it, and the "Weight" switch in the down position really takes it up a notch. It's fairly subtle when the weight toggle is up, so I'd probably just keep it down all the time. I recorded a little clip with the sag knob set to be momentarily engaged with the footswitch, so the crackly bits you hear are from when I engage it.
All in all I'd say this guy is worth it if you're looking for something a little different drive-wise, and want to add some blown out saggy goodness to it without needing to have it on all the time.
