Aion FX Neurotron carrier signal bleed
benjaminstrange
Hi everybody - long time lurker, first time poster. I've run into a few gremlins with an Aion FX Neurotron build. Everything seems to function as it should, but the VCO carrier signal is bleeding into the main signal pretty bad. I've gone through all the VCO calibration and transformer trimming as discussed in the build notes, and these seem to make no improvement to the noise issue. Have any of you experienced this, and could give me some pointers about where to begin looking to fix this problem?
Also - the blend function makes the entire signal very quiet and muted in the 12:00 position, and it really only seems to put out the proper volume all the way up or all the way down. Could this just be how the circuit was designed? I'm only really getting a decent sound from my bass blended in when the blend knob is all the way down, which doesn't exactly make it very useful.
Any insight you could provide would be greatly appreciated.
Solved, well, sort of. There's still a tiny bit of bleed, so I'm not sure how much is normally acceptable or not. I used to own a real Lovetone Ring Stinger (bought the entire line brand new in 1999, and stupidly sold them ages ago), so I can't recall if the original is this noisy or not.
The blend pot works perfectly now. Much obliged for the help!
From my own build I can tell you will not find a trimpot position where the bleed goes away 100%. It's kind of like calibrating a BBD for lowest noise floor possible. Well done!
Dear Benjamin
i seem to have the very same problem with the output mix of my neurotron build with it being a bit too low on volume in the center position.
you never mentioned how you solved that. could you give me a hint on how you solved that issue ?
This post saved me; i could not figure out how those neutrino jacks were going to fit in the enclosure with those huge lugs. Thanks!
