Median Compressor (Spirit of 1776) - Functional Testing - UPDATE
andrewsrea
As you can see from the pictures below, I have the Median Compressor populated and loaded in the enclosure for functional test. FYI: I am calling my build, the 'Spirit of 1776' - a little play on the UREI 1176 it borrows from. I had a few challenges so far:
- Reviewed the design, compared it to the UREI schematic and decided to build it stock, as it is a great design which could easily be used for bass and keys as well.
- I had accidentally selected VSSOP sized (smaller than a tick) OPA1678 IC's from Mouser, which they could not be used to the SOT-23 to SIP adapter I purchased from PedalPCB. I reordered SOT-23 size (checking the footprint specs to the adapter), which a dozen cost me $18 delivered vs. the $40 that (4) TSSOP / VSSOP adapters would have cost. I'll most likely throw away the VSSOP's, because it is unlikely I'll every have a use for them.
- For functional test, I've substituted TL072's for the OPA1678. As others have stated with their builds, you could definitely use TL072 and not spend the time and money on the OPA1678. I will be using the OPA's which I expect would have an ever-lower noise floor and transparent sound, however the TL072's had no noticeable noise floor, even with the 'Compress' (threshold) on full. The tone from them was nice and accurate.
- Surface mount MMBF5457 was my first attempt at the surface mounted FETS, which was a failure as I do not have a convenient way of auditioning and matching them. Therefore, they were never close to the targets. Luckily, I considered this might happen and had already socketed for T0-92 2N5457, which claimed to be NOS Fairchild components I bought from PedalPCB.
- Found a matched pair of these 2N5457 Fairchilds and got close to the schematic specs (Vgs = 1.43 for Q1) and found that setting resulted in symmetrical compression of a 1kHz sine wave on an oscilloscope.
To be honest, guitar compression as an effect has rarely been my thing (pumping & breathing, squishy tone, etc) and I have lots of experience with studio compressors (mostly subtle effects), which are used as gentile ways of getting an instrument or vocal to sit in a mix. That said, I really like this pedal compressor over a Ross, MXR (VCA type) or a DoD 260 (opto-resistor type). My favorite setting so far is the Compress at 8:30, Attack at 9:00, Release at 8:30, Blend at 3:00, Tone at 11:00 and Volume at 2:00ish.
Ready for paint and marking!
Before you toss the VSSOP chips, my guess is that someone here who is used to getting boards made might be interested in them. This compressor is on my next order list. Nice, clean build!
Thanks, and yes, I will hold them for someone who could use them. I have been fixing large component items (mostly tube amps and SS) since the late 70's and even though I can solder like a pro, I cannot see myself soldering something smaller than a tick. I many have between 5 and 8 left.
Finally swapped the TL072 for the recommended OPA1678 and the impact is subtle. A tad more analogous translation (sound of the guitar in = sound of the guitar out), which can sound sterile. However, into a tube amp and using the blend on 90%ish, it sounds big.
The TL072's in the Median Compressor has a noticeably lower noise floor than standard pedal compressors. The OPA1678 was lower by about 6dB, but either you would have to crank the level and compression 100%, to hear noise (which I would never operate that way).
The pedal is inherently bright, which is great for dark amps. For a bright Fender Blackpanel type amp, I keep the tone at 9 o'clock which is a tad brighter than when the effect is bypassed.
In summary, this is a soft-knee studio grade compressor that along with its blend can make an instrument sound big and sustain longer, without anyone realizing it is compressing.
Hello @andrewsrea my apologies for reviving this post but I have a question about the biasing. Q1 vgs is at about 1.4 for me at the max of the trim pot. Could this be the reason why any setting past 9:00 on the compress pot gives me distorted signal? I use 2n5457 from Tayda, and OPA2134 for all ICs if that matters. Thanks in advance!
JFET compressors are known to achieve distortion, but that typically happens with the attack and release set fast (all the way counterclockwise), then having the 'compress' (a.k.a. 'sustain' or 'ratio') up past 1 o'clock.
That said, being fully clockwise on the trim pot could be causing your particular 2N5457's to be close to, or in the 'switched off' mode. With a guitar into the pedal, the pedal into an amp and the electronics exposed (cover off), try adjusting the trim pot counterclockwise while strumming the guitar. If it suddenly clears up and gets louder, go a hair further then measure the VGS and also attempt more compression to see if it squishes'.
In my experience, 2N5457's are the most inconsistent FETs I've encountered. 1.4V for one batch may be too much or too little, depending on the batch run. If you cannot get the trim set for that pair of 2N5457's, try swapping out one's from a different batch. I've never bought from Tayda and have not heard any complaints of the quality of their components, but I have had some awful ones from Amazon and the best, from Mouser.
Substituting the OPA2134 for the OPA1678 should be okay. The OPA2134's much faster slew rate theoretically could exacerbate the onset of the distortion which normally occurs in a FET compressor, which would be reduced when the attack and release are increased. But I'd expect this difference to be subtitle and not causing the problems you describe.
Much appreciated @andrewsrea - going to digest this a bit and try sourcing 5457's I could try out, and follow your biasing/testing advice. Hopefully if I run into stuff I can always ask back here :)
Is it a bad idea to play around with the biasing network in order to reach the prescribed Vgs (as in, try and replace TR1 with a higher value trimpot to try to get more "sweep")? I figure doing so might also mess whatever biasing is done to Q2 as well but not too sure.
You can increase the value of the trimpot, if the FETs are 'off' the whole travel of the current trimpot. However, that just indicates out of tolerance FETs, which could be so out of tolerance, they cannot be used.
Reactions: ttf
Switch to smd jfets called MMBF5457, they are much more consistent than the thru holes and much cheaper.
