Leprechaun CV instead of expression pedal
Riccardo Turacchio
Hi folks I'm building a leprechaun and I was thinking of installing the jack for the expression pedal
But I will use mostly my Beatstep sequencer or LFOs so it's Control voltage and normally is just a mono mini jack,
My question is...can I just use a switched mono instead of stereo?...
That should work but keep in mind the FV-1 is a 3.3V device, it won't last very long if you hit it with a 5V CV.
If you’ve got a modular synth, the safe easy way to do this is:
• build the pedal with the normal TRS jack
• get a TRS-to-dual TS splitter cable, and patch to the In and Out of a VCA module
• use your CVs (Beatstep, LFO, etc.) to modulate the VCA
This way the pedal can only get back a modulated version of whatever voltage it’s putting out itself. No danger of cooking the FV-1.
I will check the Beatstep CV output with a multimeter but pretty sure it won't go negative...
Maybe also include a diode at this point...just for extra safety
