Fish
I’ve been working on this chop shop on and off for a little while now and when I boxed it up there was very little gain even after messing with the trim pots.  It sounded like a clean boost.
I replaced the J201’s with mmbfJ201’s and it definitely solved the gain issue but it was weak sounding(Im not sure if this od is this light of an od or not but it feels off).
Now im on the bias stage and using the test pads Im getting readings of 3.1 with the trim pots maxed out (chop shop from what I have read is looking for 6v).
I have the correct 50k trimmers
I DID NOT ground the input when testing (not sure if that was a big deal or not?)
I tried to bias with the sag down CCW and all i got was 3.1v max and got minimal gain.. I biased with the sag maxxed CW and was able to get 9.1v but when trimmed to the suggested 6v i had zero gain again.
Any suggestions?
I was thinking switching the 50k trimpots to 100k? But i have no idea if that will increased the range on dialing in the voltage.
Im still pretty new and now trying to dive into the “Why” part of this whole thing
Any suggestions?
