thunderaxe
Here's what I did with mine...
I connected a C5K CONTOUR pot + 47uF cap + 22R resistor in series and then put them in parallel with C9. With the pot fully CCW, it's the normal Expandora bass rolloff. As the pot is rotated clockwise, more and more bass comes in until at full CW the response is basically flat from 50Hz on up.
I also added a CLIP switch, similar to what reubenreub did here.
BTW, all of those cap changes you made affected the frequency response below 4Hz. C14 might help a little if you're driving a real low impedance pedal. The bass response is really all about C8, C9, R6 & R7.
hi @Chuck D. Bones, old thread i know but i had a quick question about this mod -- i get the basic idea of how it works, but i'm not clear on one thing -- does turning the C5K pot work by changing the series resistance to ground, which in conjunction with the 47uF cap changes the corner frequency of the high pass? or, does it work more like you're blending in a signal path that has a lower fixed corner frequency, and thus more like a low shelf?
