So I'm completely stumped by this
I've got an Octanaut build and everything is working except Q4
I've been through the circuit with an audio probe and there's no gain on Q4 at all. I can remove Q4 from the socket and the sound doesn't change. There is gain on Q1, that's fine. It sounds great at T1, but the volume drops after T1 and then Q4 does not bring it back up
I've reflowed the joints, double checked component placement and orientation etc
I've checked the resistance from C100 to R2 and R10 and both read 5K1
I measured~-8v on the drain for Q1 and basically 0 on the drain of Q4
I measure -.37A on the SGD for Q1 and -.37A on the drain of Q4 but 0 on the source and gate
The resistance to ground is much higher from Q4 than it is from Q1 which is probably the biggest clue?
Since the photos were taken I've changed the 10uF caps for ones that fit. The trimmer on the Q4 side was a bit stiff compared to the others so I replaced it, no change. Tried three different transistors now in Q4. I'm completely lost now
Any suggestions welcome
