Proposition Squealing
VanWhy
I get a bad squealing/whistling when I turn the gain up at all on the Proposition Distortion. Gain knob all the CCW it does not squeal.
At first I thought it could be the charge pump but it makes the noise without it in.
Could it be bad biasing with Q1? I populated RB1 and RB2 and R13 exactly from the build doc. I just most of the components. I first wanted to ask if it was anything with that JFET first then I can start double checking values of components.
Video attached. Sorry camera is moving a bunch.
Proposition Squealing Video
Solution
I've built dozens of Proposition pedals and never had one squeal like that. I won't be the JFET (Q1). My best guess would be the opamps being used. I recognize the date codes stamped on four of those TL072CP opamps and they are from a known bad batch. (I discovered them...
I've built dozens of Proposition pedals and never had one squeal like that. I won't be the JFET (Q1). My best guess would be the opamps being used. I recognize the date codes stamped on four of those TL072CP opamps and they are from a known bad batch. (I discovered them first from Tayda.) Change out the opamps and the squeal should go away.
For future reference, here is a short list of known bad batch date codes for TI TL072CP opamps . . . . .
Known Bad TL072CP Date Codes:
18MDSHY
14AP8NM
07A5L8QM
22ALE3M
Solution
18MDSHY
14AP8NM
07A5L8QM
22ALE3M
Good call. I did get them from Amazon so they are likely bunk. That is pretty easy so I'll try that first. I got some good ones from Mr. PPCB so I trust those ones.
