Looks kinda like a Recom R09P15DAmazing work! I've been working on a dual SC-40 pedal, how are you managing the 9v to 15v step? I was originally looking at using an 18v supply and a regulator down to 15v, are you using a voltage doubling circuit here? Is that the part labelled PS2 (power supply?) on your board?
Those are cool bits of kit. I've wondered how quiet they are
I used a Traco 2-0923.Amazing work! I've been working on a dual SC-40 pedal, how are you managing the 9v to 15v step? I was originally looking at using an 18v supply and a regulator down to 15v, are you using a voltage doubling circuit here? Is that the part labelled PS2 (power supply?) on your board?
If you don't mind me asking, how is the noise levels with these, and what filtering did you use around the module? I know Aion FX uses a 2-0923 in the Eclipse Boost (schematic seen in the documentation here: link), did you set up the filtering around it in a similar way? Love to see the old Ashly gear get some appreciation, I have 2 SC-40s I use for recording along with SC-50s, and want to build myself a dual pre in a stomp box so I don't have to lug the old units to shows.I used a Traco 2-0923.
I used a similar filtering like aion. The noise level is really low, no high pitch like with the 1054 - charge pumps.
I use also a SC-40 and a SC-50. I cloned the SC-50 too...
The current draw is 120mA.@disssa out of curiosity, do you happen to know the current draw of your SC-40 build? In planning to build a dual version, I'm looking at the Traco power converters, the 2-0923 outputs 67mA, but wondering how much of that the circuit uses if I need to go with a version like the TMR 4 that produces 133mA in order to supply both circuits from one supply, or if the TEC 3 models at 100mA will be sufficient. Thankss!
That's 67mA per rail, so 134mA total for the TEC 2. If current draw of one circuit is 120mA, even the TEC 3 won't work because it's limited to 200mA total.The current draw is 120mA.
I would use a TEC 3 because the range of the input voltage is better (4.5V...13.2V). The input voltage of the TMR is 9...18V. Most power supplies deliver just under 9 volts. The Tracos react very sensitively to undersupply.
Ditto ^Let me know if you have a spare PCB!
Excellent, thank you! Good to know about their sensitivity as well.The current draw is 120mA.
That's what I was thinking, if it was under 100 mA I could get away with the TEC 3. Looked at the TMR 6 too, but I think the TMR 4 will work well as my solution.That's 67mA per rail, so 134mA total for the TEC 2. If current draw of one circuit is 120mA, even the TEC 3 won't work because it's limited to 200mA total.
Edit: Had a quick looksie and TMR 6-0523 will provide more than enough current (200mA per rail). Input voltage is 4.5-9V, so some form of overvoltage protection or voltage regulation on the input would be advisable. Or just use a 12V power supply and go with the TMR 4. Not quite as pricey as the TMR 6 either.
				1&2 and 4&5Hello Disssa, amazing job once again. I am designing my PCB as well. I have one small question . When it comes to the MID Tune pot, which lugs are connected ? The schematic does not really specify. is it 1&2, 4&5 or 2&3 , 5&6 ? I have a gut feeling it's 1&2, 4&5.
Thanks in advance !
When installing the DC jack, you have to disconnect the cables.@disssa - the last picture in your first post shows the "innie" DC jack soldered to wires, which are in turn soldered to the PCB. I'm guessing you had to un-solder something and re-solder during final assembly?
Great looking build and PCB!
