Bumfluff101
- Build Rating
- 5.00 star(s)
Taking a lot of inspiration from Paul Ruby and his combo, here is my take on the 3 in 1 plus a TPA3116 poweramp.
The core is one of Paul's boards which is AMT M2 (JCM800) which has a clean and drive channel, there is a pcbguitarmania Freeman-OD to provide heavier tones and this feeds into an optional boost (another one of Paul's boards) to an always-on Arachnid.
Switching is taken care of by MasEffects relays and is (from right to left), drive select (Freeman or M2 drive), clean or drive, and boost on or off.
I also put a switch on the Arachnid to select between internal / EEPROM algorithms
This feeds into a TPA3116 poweramp with Paul's volume only board.
This was amazing fun to do and sounds epic, thank you to Paul for both the inspiration and for sharing all the work you have done.
(There isnt a random live wire floating in there, its connected to an LED)
