Chuck D. Bones
Circuit Wizard
Also known as the PedalPCB Carcass Fuzz.
This beast is everything people say it is. Quite the range of tones. Something for everybody, I suppose. I built it to stock specs, except I used 2N2222s for Q4 & Q5. Believe it or not, there's nothing that I want to change. As described in the manual, BEFORE acts as a Gain control and AFTER acts as a kind of Bias control. Maximum gain on the AFTER control happens around 2:00. Both positions of the DEMHI/HALI switch work well with my Tele. I'm looking for the "Spirit in the Sky" setting. I think DEMHI mode, with BEFORE set low and AFTER set high should do it.
These setting work pretty well for general light OD tones. Switch is in the HALI position.
L-R: VOLUME - HI-CUT - DEMHI/HALI - AFTER - BEFORE
