drgonzo1969
I came across Inverted Cross Audio in another thread and discovered they had some super reasonably priced PCBs and faceplates for a 90w KT88 amplifier ($43 for both). I have been on the fence about starting an amp build for too long so I decided to grab the PCBs and start the amp building journey. Inverted Cross Audio has links to parts in the BOM but they are based in Spain and shipping would be expensive for all the hardware so I am going to source most of the parts through the usual suspects of Antique Electronic Supply, Tayda, and Mouser. I've found the chassis, most of the resistors and capacitors, but I need help sourcing the output and power transformers. Also, I could use help finding this power switch and impedance selector. PCBs should get here in a week or so. Here is a link to the BOM and the parts I need help sourcing. Thanks in advance for any input and advice.
invertedcrossaudio.com
www.tubetown.net
www.tubetown.net
THUNDERDOME - Inverted Cross Audio
Tour friendly high gain amp with two channels (clean/lead). 90 watts output power provided by 2xKT88 output tubes, 4xECC83 preamp tubes. Flightcase and footswitch included. Controls: clean gain, lead gain, mids, low, high, clean master, lead master, presence. Switches: off/standby/on, channel...
Toggle Switch APEM 644 H/2 DP3T - ON-(OFF)-ON
Toggle-Switch, used by Orange-Amps Type: Toggle Switch Version: DP3T - ON-(OFF)-ON Rating: 15A / 250VAC, 10A / 400VAC Contact resistance: 10 mΩ max. at 1A 2VDC Insulation resistance: 1.000 MΩ min. at 500VDC Dielectric strength: ...
Rotary Switch 1-Pol / 3-Pos - 4 A @ 250VAC - Impedance / Voltage Selector
High Power Rotary Switch - Can be used as Voltage or Impedance selector 1 pole / 3 position Solder lugs Shaft Diameter 6 mm, D-Shaft Rating: 250 VAC 6(4) A Contact Resistance: 100MOhm Max Dielectric Intensity: 1500VAC / 5S for ...
