*Renamed the thread as it is primarily about FET designs.
Hey folks, so I've been reading Merlin Blencowe's Designing Guitar Preamp book. One thing that has interested me is the effect of essentially a poor design leading to some current leaking into the grid of the follower and therefore leading to some signal compression.
This excerpt is especially interesting
He then goes on to mention that bootstrapping the stage as in the following example will exaggerate this effect (show at the end of the post). My question is, would it be possible at reasonable voltages (and by this I mean up to 24v I guess) to replicate this effect with a JFET or a Depletion MOSFET like the LND150? I think that would make a pretty nice addition to a "clean" boost that still helps control transients.
I did just get some 6n16b in the mail which I would be interested to in maybe using as the basis for a preamp. Maybe adapting the Vox Cathode follower stage to bootstrapping and using the 6n16b instead for lower overall gain. But then, how much is gain a factor in the amount of compression?
Because the ECC83 is a high ra (anode resistance) valve, it is difficult to bias properly if the grid voltage is high and the cathode load resistor is not sufficiently large—as any classic textbook will indicate. If the supply voltages in the Fender Bassman had been much lower, or if the cathode load resistor had been properly chosen, this effect might not have been realized—and the amp may not have become the icon it is today. Similarly, if a lower ra valve were plugged into this same circuit, we probably wouldn't generate any quiescent grid current, and again, we would not obtain the characteristic compression effect. (Of course, this effect can be duplicated with any valve, provided the resistor values are suitably chosen.)
