Aleph Null
This circuit started out as an Electra Distortion. I kept tweaking and adding the features on my wish list  until I ended up somewhere very different. I think it works best pushing a dirty amp, but it certainly sounds good on it's own as a low to mid-gain overdrive. It's pretty versatile, especially given the low parts count.
The knob placement required using a mix of 16mm and 9mm pots, but I think the aesthetic effect was worth the inconvenience. I attempted a hydro dip finish and failed...so I moved on to a paint splash finish. The perspicacious among you will notice that the PCB is labeled "Electra Supreme"; I had ordered the PCBs before the name came to me.
The soldering around the diodes looks a little sloppy because I tested multiple sets before settling on 1N60s. BAT46, 1N60P, and 1N34A also work well.
An input cap blend acts as a pre-gain Lows control. This feeds what was originally the Electra. The bias is set up so that the Gain can be adjusted without scratching. The real innovation here is the Texture control. This blends continuously between symmetric clipping when fully counterclockwise to highly asymmetric clipping when clockwise. This changes the harmonic content of the overdrive in a way that a normal "mids" eq would not. High Gain and Texture settings start to border on octave fuzz sounds—especially if you push the front end with something else. Next is a make-up gain stage with a presence boost around 2kHz. Boosting the treble after the clipping stage does mean this circuit can get a little noisy in some settings, but the presence boost provides a sizzle that I think makes it worth it. This is followed by a fairly standard passive Highs tone control and then the Volume.
Here's a demo:
As always, I have extra PCBs if anyone is interested in building one. Just DM me.
Here's a demo:
