Hello, I recently built the TwoToneFuzz it works but there are some problems...
Well on the MK2 setting there is this high pitch squell, I have to lower the impede and gain to make it somewhat bearable. It is coming from the pedal, the guitar volume doesn't effect it.
On the MK1,5 it is there too, just barely hearable.
(Will add photo and vid soon)
I think it is something transistor related I tried adding the 47/100pF cap between the legs, didn't help.
And the other problem, I used germanium transistors. Well the Q2 only work with one from my batch of about 10. Otherwise it is always gated and the bias works two ways. All transistors work fine in Q1 and Q3 even in my treble booster circuit. Don't know the exact type and values
I tired measuring the voltage at Collector and it all seems normal.
Also the ON/ON switch is slightly buggy, I need to change it, I have to click it twice into position. But this shouldn't be the cause if I am not mistaken.
Thanks for any help, tips with trouble shooting
