Good question, I’ll check my notes. My current build has a 1uF in place.Did you work out the capacitance with C2 in series with the voicing caps ? I think that C2 will affect the value of the wet HPF caps just a tiny bit but the higher C2 is the less effect it will have.
Ooooooooo, I like the idea of turning the Bassdude into a JTM45!This might be one mod on the BassDude that not many have thought of, change a few values on some components and add a second Bright cap on top of R12 and you have a Marshall JTM45 preamp, of course the JTM45 has 2 channels, one with and one without Bright caps so place both caps on a switch if you do this mod.
What do we need to do?
We could place a 68k resistor between the input jack and the PCB but I would not do that, the only real difference is that V2A does not have a cathode capacitor C9 and we need to add the 500pF Bright capacitor on top of R12.
R16-1k6, R17-820R, C8-100uF (120uF), C9-Leave Out, R12-Add a 500pF capacitor over the top, Tone Stack-please yourself with this one.
The more serious modder would also change the tone stack to a classic Marshall tone stack, we would just mount the pots in the box and then wire the resistor and the 3 capacitors to the pots themself and then run 3 wires to the PCB at the right places. ( C7 / C10 junction and R15 / Master junction and also a ground wire )
If you build a JTM45 BassDude then it might make sense to try some 12AY7 tubes in the real BassDude so they sound different, you might just need one 12AY7 and one 12AX7 in the BassDude but you just have to experiment with different tubes.
Hi @SamuelG. I replicated you Bathtub Reverb mod, and it’s amazing! Thanks for sharing and documenting it. I also used the shielded cable where you did, but I wonder how much noise would be introduced if I hadn’t used shielded cable. Did you try it at first without shielded cable and experience unwanted noise or were you just being cautious?Here is a sample of my updated MOD for the Bathtup Reverb.
Note that the Dry path stays clean:[This is my original case, not my updated graphic]
Hi,Hi @SamuelG. I replicated you Bathtub Reverb mod, and it’s amazing! Thanks for sharing and documenting it. I also used the shielded cable where you did, but I wonder how much noise would be introduced if I hadn’t used shielded cable. Did you try it at first without shielded cable and experience unwanted noise or were you just being cautious?
I like that little tune in the clip, did you download it or make it ?Here is a sample of my updated MOD for the Bathtup Reverb.
Hey @SamuelG , could you clarify this a little, please? Do you mean the dry signal, or the wet? What do you mean with "I didn't change the Fc when I shift C2 down to 0.47uF"? I wanted to follow your instructions above, where the 0,47uF for C2 should give a Fc of 21.9Hz, but now I am confused a little ... Thanks a lot!I did notice that I didn't change the Fc when I shift C2 down to 0.47uF. At this value, the Fc is between 50 - 40Hz at -3dB/octave depending on where the mix pot is set.
I think I'd go back to a C2 at 1uF which gives me a Fc ~20Hz.
0.68uF would get an Fc ~30Hz.
Thanks a lot! But why did you say, you want to go back to 1uF? If I understood you right, then the 470nF C2 will cut the dry signal at 40-50 Hz (which would be to high for me). I am afraid I will cut my dry signal to much with the 470nF. A 40 Hz Low Cut for Bass Guitar is audible and will cause phase issues. So I want to have Fc at a smaller frequency. If I got you right, the 1uF value is best for this. I ordered some 1uF 400V film caps from Siemens/Epcos, which have 23 x 11 x 8,5 mm. So I hope they will fit under the PCB.Hey Winterbloom,
From the original design, I change the high voltage C2 to 0.47uF. In my first effort I used a 1uF cap because that is what I had on hand. But a high voltage 1uF cap is large! So, if you use a 0.47uF HV cap, you will not have any audible HPF from the C2 coupling cap. After C2, there is a dry path (tube only) and a wet path (through the reverb module). So, for size sake, I’d recommend you instal a HV 0.47uF cap on the underside of the PCB.
Per “I didn’t change the Fc when I shift C2 down to 0.47uF” I was referring to lowering the overall C2 capacitance from my original 1uF cap to a smaller 0.47uF cap. This reduction in C2 capacitance does not impact the Dry signal and it does not impact the HPF settings of the switched caps (this is because of how capacitance adds up in series circuits).
Hope this helps.
