Order Switcher Orientation
Mr. Strypes
Hi, friends! I’m installing a PedalPCB order switcher in a dual-effect build. Which circuit is first in the chain when the toggle switch is in the up position? S1/R1 or S2/R2? It appears to be #1, but I want to confirm before creating a label for the pedal. Thanks!
With the board oriented the same direction as the picture S2/R2 will be first in the chain when the toggle is up.
(When the toggle lever is up the lower set of lugs is connected, when the lever is down the upper set of lugs is connected)
Right on! Thanks, Robert!
