That's for the 50,000 watt resistor yo.....
So many toanz!Got these guys off fleabay fairly cheap, going give them a whirl.
How do you keep the tower of power from tipping? I am 2 high in one place and it is sketchy at best. Drilled into the wall?
those silkscreened panels are pretty dope, thoughThe joys of second hand DIY Heathkit!
The power of gravityHow do you keep the tower of power from tipping? I am 2 high in one place and it is sketchy at best. Drilled into the wall?
The LEDI made a big mistake with this faceplate that I fixed today. Will update with another picture later tonight. Can you spot the mistake?
Well, yeah I didn’t take that into account initially because the drill template does not have the LED. But that’s been fixed in the pic above. There is another, pretty big problem in the pic above.The LED
Thanks! This material turns out really well. It’s the best I’ve found.Damn that's a clean faceplate!!
The white wa-Can you see the difference now?
