Dr. Robert (“Pharmacist”) w/Tayda UV Print
3.00 star(s)
“Had” to build this TWICE. It was the first pedal I’ve built that didn’t spring to life when I plugged it in. I troubleshooted and traced it until I couldn’t take it anymore, jacked up the PCB removing my better components, and started over.
It was only later that I discovered the “issue” with the original 🤦🏻‍♂️: I made 3D printed enclosures to temporarily house 3 pedal builds while waiting for my Tayda enclosures. Two (per the wiring diagrams) had ground wires from the input jack to the power jack and the output jack, and worked great in their temporary PET-G homes. This one did not (and couldn’t use the ENCLOSURE for ground because it was plastic). Tough lesson learned!
Now that it’s done, I’m thrilled though! I wanted the graphics to be unique so I used the bottom half of a pretty rare Klaus Voorman poster. Plugged it in last night, added a Keeley Abby Chamber Verb and played my best “She Said, She Said” on my Elitist Casino. I can tell already this one’s going to be a frequent “go-to!”
I had to build this one twice too but never figured out what was wrong with the first one.
SO much to go wrong with this build. And so many components that probing is a bear. I also noticed that the PCB didn't hold up well to desoldering (when I was changing out components "in case" for lack of any obvious issues) - never experienced that with other PCBs.
Nice! I like how you used terminal blocks for connecting the I/O and power wires. I don’t recall seeing that before.
Thanks! I first started using them a while back for the power input (and LEDs, if the blocks fit) since with those you have to desolder/resolder to pull the board from the enclosure (to, e.g., troubleshoot, design the enclosure, etc.). Now I just use them wherever possible.
