DEMO The Everlasting Tantrum - an enhanced DOD Grindhaus Fuzz
leadfoot
5.00 star(s)
After seeing a request for an unreleased DOD / Devi Ever collaboration pedal and looking into it I decided to go ahead and use it as a learning exercise to move off of EasyEDA and into KiCAD for my PCB designs. Plus, I'm a huge fan of fuzz pedals, so it made a lot of sense in my mind. The general layout of the unreleased circuit is a Hyperion into a Big Muff style tone stack with a boost tacked on at the end. As someone who can never leave well enough alone, I added a few things: a tone bypass, an on/off/on switch to change the fuzz circuit between three Devi Ever fuzzes (Hyperion, Ruiner, Bass Ruiner) and a feedback potentiometer in case any of the three fuzz modes wasn't nasty enough for you you've now got the ability to make it sound even better (worse?) if you'd like.
On the faceplate I decided to be Spaceman-esque with a dash of Sheepylove and the see-through light up logo. When turned on, you get a light up succubus, cause well, why not?
As far as the PCBs and such, I had a few rookie mistakes: mislabeling the oscillation value to 100kA instead of 10kA (100kA is usable just 10kA is easier to dial in) and on the faceplate, I didn't recheck my spacing for the switches, so it didn't line up as easily as I would have liked. Both have been corrected in the files below
If a weird mashup of Devi Ever, Big Muff tone stacks, and make up boosts seems like fun to you and you want the gerbers for the PCB and faceplate you can get them here (where I also created a Tayda Drill Template too) or I've got some PCBs as well from my first run (the oscillation pot is still labeled at 100kA).
On the actual build, I chose the purple fury 125B from Stomp Box Parts along with their anodized purple knobs for that high class look. I used a white LED mounted directly against the board to get a nice fill of the logo.
Obligatory Demo:
Obligatory Images below:
Nice, what value CLR have you got there? I tend to go for 3k3 or 3k6 (depending on which is easier to get out) and it works well.
This one is a clear LED with a 1k-ish CLR. I built a second one with a purple LED and a 3k resistor but wasn't as vibrant.
Super cool! I used to sell this exact configuration, and a sm/vfm with the same features (switchable big muff tone stack with post boost) and a voltage starve.
I'm a huge fan of voltage starve on fuzz circuits; I just ran out of room on this one. I guess that means I'll have a second revision at some point. :)
If i recall, the hype doesn't do much when starved. I don't think i ever put one on it to stay.
Regarding the voltage starve - I assume you just used a pot as a rheostat like most do, maybe with a small resistor in series to protect it... I've done that with good results, but once in a while I'll see someone suggest setting up a starve pot as a voltage divider instead, with the third lug going to ground. I'm still not quite sure what the audible difference is between the two methods, and if/why the voltage divider would be preferable to a simple rheostat in certain situations.
I used the pot as a rheostat in this design and that is how I've normally done it. I've tried setting up the starve pot as a voltage divider with the third lug going through a resistor to ground to at least have some voltage going through and haven't had the results I was looking for with the circuit section I was attempting to starve.
I changed my "(y)" to "😻"... must not've had coffee or something when I first saw this. Glad it came up on my radar again.
Really, what's not to love about this build? It's super slick and the purple pops and the LED silhoutte is so detailed!!!!!
On top of that Gerbers and drill template given... woohoooo, Icing on the Cake!
