As you can see, the ground is connected to the two audio jacks, the foot switch as the ground for the bypass LED, and the actual ground from the 9V jack.
The PCB probably has a ground plane, connecting all the grounds together, and filling any empty space on the board, it's just not showing it - it's not typically labelled. This would connect with any other grounds for the circuit. As an example, the 7.5K resistor above probably has one pad going to ground as well.
