Monarch
It's all about getting the JFET biasing right. JFET circuits are not plug-n-play. Plan on selecting R4 & R12. Stock values might work, but there is no guarantee.
We're looking for around 5V on Q1-D. If it's higher than 5.5V or lower than 4.5V, then adjust R4. Increasing R4 makes Q1-D go up and vice-versa.
We want the current in Q2 to be between 1mA and 2mA. Measure the voltage on Q2-S, divide by the value of R12 and you have the current. Increase R12 to make the current lower and vice-versa.
Here's an easy trick. Assemble the board but do not solder R4 or R12. Wedge toothpicks in the 4 unsoldered holes so that the leads on R4 & R12 are held tightly in their respective holes. Power up the circuit and measure Q1-D. If it's outside the range of 4.5V to 5.5V, then remove R4 and try a different value. Use the same process for R12. Once you have the correct resistor values, solder them in.
Take your time with the build, inspect your work often making sure you installed the parts correctly and the solder joints are clean. Do a very thorough inspection and cleaning before installing the pots because once they're in, rework becomes much more difficult.
Good luck!
I am thinking of building this but the through-hole JFETs you mention are hard to get here. One place has suggested subbing BF256B JFETs because they have them in stock. I don't have a clue if they would work or not. Do you have any experience with the BF256B?
FWIW the MMBT5089 is the SMD equivalent and readily available (and cheap).
That's a BJT and as such is not a sub for any JFET
BF256B will have lower gain. J113 is a better sub and readily available. Adjust R4 and/or R12 in accordance with post #106.
